The Best Hyperconverged Infrastructure (HCI) for Enterprise ROBO, SMB & Edge
Adjusting Chunk Size for StarWind Devices in Proxmox
  • Guidance
  • October 29, 2025
Description
By default, the LVM thin pool uses a 64 KB chunk size, which is suitable for devices up to 16 TB. When a StarWind device exceeds this size, the default chunk size must be increased to prevent allocation or performance issues.
Use the following recommendations:
  • 128 KB chunk size – for devices up to 32 TB
  • 256 KB chunk size – for devices up to 64 TB
NOTE: The thin_pool_chunk_size parameter appears only after the StarLVM plugin is installed in Proxmox. Make sure the plugin is installed before proceeding: https://www.starwindsoftware.com/resource-library/starwind-x-proxmox-san-integration-configuration-guide/
Steps
  1. Open the LVM configuration file
    Access the Proxmox CLI and open the lvmlocal.conf file for editing:
    nano /etc/lvm/lvmlocal.conf
  2. Modify the chunk size value
    Find the line containing thin_pool_chunk_size and change its value:
    thin_pool_chunk_size = 128
  3. Create the physical volume
    Once the configuration is saved, create a new physical volume using:
    pvcreate /dev/<device_name>
    Then, continue creating a StarWind LUN in Proxmox following the standard deployment guide.
  4. Validate the configuration
    To confirm there are no storage restrictions, perform a test migration of a virtual machine.
When deploying StarWind devices larger than 16 TB in Proxmox, adjusting the thin_pool_chunk_size parameter is required to ensure proper thin pool operation. Configuring the chunk size before creating a physical volume prevents allocation errors and ensures consistent storage performance.
