The Best Hyperconverged Infrastructure (HCI) for Enterprise ROBO, SMB & Edge
Changing, adding and disabling L1 cache – VSAN for vSphere
More information about L1 сache is available on the link: https://knowledgebase.starwindsoftware.com/explanation/starwind-virtual-san-l1-and-l2-caches-operational-principles/
NOTE: It is not recommended to configure cache in Write-Back mode on Standalone devices in order to avoid possible data corruption upon power outage or incorrect service shutdown.
Disabling cache
1. Stop the StarWind service.
2. Check the path to the .swdsk file(s) in StarWind Management Console. It is in the same folder which contains the .img file.
For example, VSA Storage\mnt\disk1\disk1.
3. Open the folder containing the *.swdsk StarWind device header file(s). Please make sure that there is a copy of the .swdsk files before editing them:
4. These are the lines to be removed from *.swdsk device header file(s):
       <caching>
         <cache type="write-back" size="128" units="MB" level="1">
           <storages>
             <storage_ref id="1"/>
           </storages>
         </cache>
       </caching>
and
       <storage id="1" name="RAM" type="RAM">
         <interval size="128" units="MB"/>
       </storage>
NOTE: Units and size values may differ from the ones provided in the above example.
5. Save the file(s).
6. Start the StarWind service.
Wait for synchronization to complete, then repeat the same steps on the other node(s).
Changing cache size and type
3. Open the folder containing the *.swdsk header file(s). Please make sure that there is a copy of the .swdsk files before editing them:
4. These are the lines to be edited from *.swdsk header file(s):
 <caching>
           <storages>
           </storages>
         </cache>
       </caching>
and
       </storage>
where:
Parameter Value Description
cache type write-through Storage method in which data is written into the cache and the corresponding main memory location at the same time. The cached data allows for fast retrieval on demand, while the same data in main memory ensures that nothing gets lost if a crash, power failure, or other system disruption occurs.
write-back During idle machine cycles, the data are written from the cache into memory or onto disk. Write back caches improve performance, because writing to the high-speed cache is faster than to normal RAM or disk. Using write-back cache for disks adds a slight amount of risk, because the data remain in volatile memory longer.
size {value} Cache size in the corresponding units “MB”, “GB”.
storage_ref id
storage id
{value}
{value}
“Storage id” and “storage_ref id” should be the same for device type, but differ from 1, because the main device storage has this reference index. You can set this number to 3 or 4, for example.
Adding cache
NOTE: “Storage id” and “storage_ref id” should be the same for device type, but differ from 1, because the main device storage has this reference index. You can set this number to 3 or 4.
These are the lines to be added to both .swdsk HA and image header files of the device:
  • After the closing </geometry> tag:
 <caching>
            <storages>
              <storage_ref id="4"/>
            </storages>
          </cache>
        </caching>
  • After the <storages> tag which is below the <resources> tag:
 <resources>
          <storages>
            <storage id="4" name="RAM" type="RAM">
            </storage>
where:
storage_ref id
storage id
{value}
{value}
4. Save the file(s).
5. Start the StarWind service.
Hey! Looking for a cost-effective, high-performance, and easy-to-use hyperconverged platform?
Taras Shved
Taras ShvedStarWind HCI Appliance Product Manager
Look no further! StarWind HCI Appliance (HCA) is a plug-and-play solution that combines compute, storage, networking, and virtualization software into a single easy-to-use hyperconverged platform. It's designed to significantly trim your IT costs and save valuable time. Interested in learning more? Book your StarWind Virtual HCI Appliance demo now to see it in action!
